SR20 DET WARM ENGINE START UP PROBLEM
jojy
Car: nissan 200sx & toyota mr2
its funny,but engine om my 200sx starts perfectly when its cold.once the engine is warm it didn't start (( can anyone help???
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
ecu water temp sensor or maf
jojy
maf-??? what is this?
USMCgetsome
mass air flow sensor it is connected to your turbo inlet pipe and air filter. Sometimes when mafs fail it reduces power and will gradually get worse and shut your motor off while driving at normal temps. It will spit and sputter then when coming to a stop or neutral the motor will just die. if you had an aftermarket ecu or nistune you can see the voltages that the sensors are producing
jojy
the problem is that the ecu and whole car is ca18 det the ex owner had changed the engine on sr 20det without changing the ecu .so now everything in this car works good except this "small" problem
zach-Ka
Car: 1990 240sx (SR)
USMCgetsome wrote:ecu water temp sensor or maf
Agreed, Coolant Temp. sensor IMO.http://www.frsport.com/Nissan-....html
