sr20 de head on det block
iam2pro4u
Car: 1995 240sx rb25
Alright well i searched a little before posting and couldnt find nething. So i bought a s13 and it has a sr20de in it. Well i have a turboed block in the garage that im building. Basically what im wondering is can i use the n/a head even with it running with distributor? Also is it even worth doing? Or should i just go ahead and buy a det head also? Thanks for any info.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Same head, it's not like a FWD SR head.
Build away!
iam2pro4u
Alright thats awesome. Would you suggest switchin to coilpacks or stay with the distributor setup?
Seishuku
Depends, are you doing to use a DE or DET ECU?
If you got the DET ECU, harness, CAS, etc, then run that.
iam2pro4u
No i dont have ne of that. ive heard you can get a ka ecu and send to jim wolf and have it tuned for the sr running distributor and turboed. Is this true. Or should i just buy a det ecu harness etc..
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
In my opinion the coil pack and CAS set-up is going to be more reliable, the extra heat from the turbo will destroy the ignition wires on a distributor set-up. Spend the money and use the SR20DET set-up
iam2pro4u
ok maybe ill do just that id hate to make it more difficult then it needs to be lol
