sr20 crank, no start
edlugz
Car: 1993 nissan 240sx se redtop sr20det
my 93 s13 died shortly after starting it today, the idle was very rough then then it turned off, wont start now just cranks, i can hear the fuel pump activate when i turn the ignition on and ive checked for spark, the plug was sparking but seemed weak to me. ive had the sr for over four years and this is the first issue ive had with it, any ideas guys?
Encryptshun
Car: 2005 Nissan Xterra
You said you were getting spark, but are the plugs old? Were they fouled? Did you check all the plugs or just one?
edlugz
Just checked one, the sudden failure leads me to believe that fouled plugs wouldn't be the cause, I've ordered another fuel pump and gonna go from there
