vanquish2 »
https://forums.nicoclub.com/vanquish2-u59270.html
Tue Dec 23, 2008 11:31 am
Ok heres your problem....check pin 34 I think on the ecu....orange wire....
hook a voltmeter up to it and make sure that it is getting 12 volts when you turn the key to START....this should only see 12v when the start is turning.
This 12v signal tells the ecu to go into a "start map". When this doesn't happen it is a PAIN to start when its cold.....
If its not getting this signal and you want to repair it all you have to do is either hook it to a switch to goes to 12v and just flip the switch to off once the engine starts.......however, the best way is to find to correct wire in the ignition switch and make sure it is sending the signal to the wire......
check that wire and let us know......
I fought with this for 5 years and FINALLY fixed this a few months ago......
good luck!
