SR20 build
kooltacos
list
Hijacker
Car: '92 240sx Convertible
'94 F-150
Oof. Time for a new head, too.
What happened to cause the piston to destruct?
kooltacos
Hijacker wrote:Oof. Time for a new head, too.
I think it's just baked on oil crust, it was just the #1 cylinder.
Most likely a prolonged lean condition/bad waste gate, I purchased the car in this condition...it ran, but not very good. It didn't even have a boost gauge, much less a wide band.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Man and srs are usually pretty resilient to Abuse. This one puts the icing on the cake!lol
kooltacos
got some parts in
kooltacos
cleaned
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Cosworth.
The block deck surface looks a little rough though...
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
I hope your had your front cover/oil pump machined also since you had the block decked.
kooltacos
CSUPUEBLOTIM wrote:I hope your had your front cover/oil pump machined also since you had the block decked.
I did.
kooltacos
yep
CSUPUEBLOTIM
Keep it up. I am just a little bit ahead of you on my build, but I think you got more done in a short time. haha. I am waiting for my arp head studs to get here then i will be able to bolt my head on. I ended up getting another upper pan cause I had mine notched and being picky like I am, I was like o let me just smooth it out some more and I ended up blowing a hole through it. I might just mark it, drill holes through it and weld an aluminum plate on the outside. I wasn't to sold on machining down a brand new stud, but that's just me.
