sr20 bore taper
ricardo.benin
Car: 1991 240sx
Hi I am doing a stock rebuild on my sr20det blacktop and my two inner bores 2 and 3 have about .0025 taper and my outer bores 1 and 4 have .0005 taper, so my question is this can I get away with the inner taper on stock pistons, BTW my fsm does not give me a max allowable taper so we're could I find it.
Thanks
PapaSmurf2k3
Site Admin
I'm guessing you're talking inches, not mm.
The .0025 is a bit much. You should probably just bore it out.
