Msregor »
https://forums.nicoclub.com/msregor-u203906.html
Mon May 07, 2012 10:37 pm
So I've been dealing with a bogging issue for a while now. I have a blacktop sr20 with JE pistons, BC rods, apexi head gasket, BC valve springs/retainers, BC stage 2 cams, greddy RZ bov (uncirculated), greddy fmic, profec b, apexi exhaust, stock turbo, stock fuel injectors, and walbro 255. Engine work was done prior to me buying the car. Car has been bogging for a while now. Since then i tried changing the coolant temp sensor but made it worse. New o2 sensor. New spark plugs. Rewired mafs. Cleaned/replaced grounds. Cleaned pcv. Everything I did (with the exception of the cts) made it a little better. I was having issues with the battery dying. The battery had officially gone bad. So my friend brings me a battery and the bogging disappeared. For two days the car ran great. Then started in with the bogging again. Tested the alt and it was bad as well. Replaced the alt added a ground and recharged the battery. Car ran the same. Drives ok for a couple minutes then bucks and bogs. Voltage gauge shows below 12. Turbo timer volt gauge jumps from 13.2 - 11.9. Haven't cleaned iacv. Havent checked voltage on tps. Ecu shows code 55. I'm ready to blow the car up. Any suggestions would be greatly appreciated. Thanks
