KYZAAC »
https://forums.nicoclub.com/kyzaac-u147135.html
Tue Oct 04, 2011 7:13 pm
i've been having nothing but problems with this swap, its all been in the wiring, wiring specialties did my harness first. i was blowing 100a fuses at the distribution block thats hooked up to the battery relocation, someone told me the starter draws over 100a thats what the fuse was popping, i hooked the battery back to stock and hooked the starter up direct and it fried a coilpack. the coil harness was wired wrong, i bought 4 new coil packs and a new harness, but was still blowing fuses, i was talking to a mechanic and he said the starter wire shouldnt be fused anyway so i left it hooked up direct.
i noticed i wasnt getting spark, i tested the ignitor chip and it was bad, so i ordered one off ebay, plugged that in and still no spark, after checking everything in the harness i packed it up and sent it to josh at 240sxtechdvds.org, he checked and tested everything, he said all was good except both ignitors were f***. i ordered another ignitor, tried to start the car, it started for a second and died. and no spark yet again, so something is blowing the ignitors, and josh says its not the harness.
what else could it be?
