sr20 block and neo vvl head swap question
USsil80
hello.. i have been thinking about doing a neo vvl head swap on my sr20det red top..my question is ..are all sr blocks the same as far as cooling channels and oil passeges that lead to the head.. aslo if anybody body has any info on this swap would be great..thanks...mm vtec
Nismo_Freak
Car: 89 Nissan 240SX
I am working on this swap first with an N/A engine using a 16VE head.
As far as bolting onto a DET you will have issues due to the differences in manifolds, etc.
VitaminT
Car: 93 240sx SE
I posted a good bit of info on this somewhere not long ago. Might have been one of those other forums.
You will have to run an external oil supply to the vvl soliniods. Try to find a post(s) by my same name on freshalloy...I think that is where it was. About 1-2 weeks ago we had a pretty goo discussion about it. Also for real good info search on sr20forum.com. They are mostly a fwd forum and are 1-2 guys that have at least posted a decent amount of info.
I hope by bringing this up you know that you are more than likely going to have to mod/beat in your firewall due to clearance.
USsil80
man i am really am thinking about this swap... along with a FAST ems ... just have to fab up a turbo mani and a intake mani... think this is going to be hot...
VitaminT
Car: 93 240sx SE
For turbo or NA? If turbo why not just use a modded GTiR ITB mani. It should bolt up and with the low port head clear the hood.
USsil80
that might work....... what do you mean "modded".... it is for boost.... have a sr20det... just looking for something fun...want to get a used (decent condition) head gasget from a sr20ve... think i might try to buy one tomorrow of of sr20forum or something like that... plus i am going to use a summit piece to activate the cams.... so don't have to worry about the ecu..
SillyRB
USsil80 wrote:want to get a used (decent condition) head gasget from a sr20ve... think i might try to buy one tomorrow of of sr20forum or something like that... plus i am going to use a summit piece to activate the cams.... so don't have to worry about the ecu..
MSD works alot better and is easier, you just put a pill in there for when the low / high cam feature to ACTIVATE
and for the headgasket a SR20 headgasket is the same for the fwd'swhether is a DE, DE-T, or a VE.
USsil80
what about the hole you have to plug up becouse it doesn't line up.... anybody know a good place where i can get aq head from
VitaminT
Car: 93 240sx SE
What hole are you talking about?
I would check the classifieds on sr20forums.com. They are on there a pretty good bit.
USsil80
from what i have researched you have to plug a hole in the block... something about a oil feed to the head that doesn't line up.. i am also thinking about using the sr20det CAS instead of the distributar so i can use the aem plug and play and have more room between the engine and the firewall
Nismo_Freak
USsil80 wrote:from what i have researched you have to plug a hole in the block... something about a oil feed to the head that doesn't line up.. i am also thinking about using the sr20det CAS instead of the distributar so i can use the aem plug and play and have more room between the engine and the firewall
It's the oil feed from the block to the VVL solenoid that isn't on the D heads. Thats why you have to tap the block for a oil pressure line to the solenoids.
Nismo_Freak
Oh and I'd just cut a hole in the firewall for the CAS as you will need to time it and adjust the timing.
USsil80
i was thinking about using the fast engine management.. so i would not be using any stock sensors (exept the cam activator ones).. thos just make a block off plate on the distributor hole..
VitaminT
Car: 93 240sx SE
You will still need to make room for the solenoids. They stick out a good way.
