Postby
drEameRvaJ »
https://forums.nicoclub.com/dreamervaj-u24957.htmlMon Oct 16, 2006 8:06 pm
What could I use from a Blitz FMIC w/ piping that was meant for a SR20? Could I be able to use anything? Let me know. Thanks!
Modified by drEameRvaJ at 2:41 AM 10/17/2006
Postby
lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.htmlMon Oct 16, 2006 9:07 pm
if you're using a bottom mount the hot pipe might work.. if not, you'll have to make your own upper hot pipe section, but no matter the cold pipe should fit.
Postby
drEameRvaJ »
https://forums.nicoclub.com/dreamervaj-u24957.htmlTue Oct 17, 2006 7:08 am
lrb_2000 wrote:if you're using a bottom mount the hot pipe might work.. if not, you'll have to make your own upper hot pipe section, but no matter the cold pipe should fit.
JGS LOG Manifold. Should it work? Anyone else with info.!?
Postby
lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.htmlTue Oct 17, 2006 12:40 pm
I have a SR coldpipe, and bottom half of the hot pipe on my s13.. it fit perfect.... so you'll need to make your own hot pipe probably.. it's not difficult.
Postby
drEameRvaJ »
https://forums.nicoclub.com/dreamervaj-u24957.htmlTue Oct 17, 2006 5:50 pm
Thank you. My cousin has a SR BLITZ FMIC, and I was wondering if it would fit on my KA, cause I know I would save a lot of $$ if I bought it from him. THANKS again!
