I used to run an auto 63 ecu on my redtop for years. The idle was above 2000. It went down when I disconnected a light blue wire near the ecu.duffman1278 wrote:It shouldn't be THAT high though because I'm using an auto ECU on my redtop and it doesn't idle at 2k RPM.
Have you tried to adjust your throttle cable?jetblack24 wrote:Ok so i feel really dumb posting this as i should be able to figure this out, but i have an sr20 blacktop that is idling around 2,000. I tightened that little plastic idle screw as far down as i could which dropped it from its original idle of 3,000, but i tightened so tight thats its stripped now. Anyone got any ideas on a means of fixing this?
Thanks
