SR20 ATC plug pin out
NoHope240
Car: 1991 240sx s1315
I need a pinout of the auto trans plug (the other plug under the dash) for sr20. All of the fsms online have omitted the AT section from the manual. If anybody has one or knows where to find a FULL sr20 fsm let me know.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
The FAQ had your answer.
sr-ecu-pinouts-t495077.html
NoHope240
NO not it. I have the ecu pinout and wiring diagrams for the entire harness except the plug that goes to the automatic transmission control unit the second plug under the dash goes to it you will not have this plug with a 5 speed the plug is a 14 pin on the ka harness and i found what they all do using a ka fsm it was in the AT section, The sr has the same plug with 1 extra pin and few wires that are different colors i was told they will not need to rewired but i would like to make sure. You cannot trace this without the AT section of a SR fsm but like i said they are all omitted from the ones i found.
