Sr20 Aem ems. Touch the gas, goes lean then normal
A place to discuss the systems and methods of tuning Nissan engines.
clever240sx
Car: Nissan 240sx
I just installed aem on my sr20. Its a built sr, greddy intake mani, gt30, and its on e85. I have a guy tuning it right now but hes running into a problem. When you punch the gas it leans out(feels like it burps) then goes back to normal afrs in a split second and then drives fine until i punch the gas again. Anybody know the fix? Im pretty sure it has something to do with the accel tables but not sure what to put in them.
S14toRPS13
Not too familiar with AEM EMS, but don't they have the option of uploading a base map. That'd help out a lot more than just doing guess work.
clever240sx
Car: Nissan 240sx
Yes they have a base map and we went off that during the tune but this problem is still occurring.
solowsr240
Car: 91 240sx with built sr20det, fullrace t4 gt35r, 2000cc injectors, z32 trans
My car also had the same problem for alittle while, but im running a q45 tb, you should be able to just watch the indicator on the main fuel map, and riched it up where its falling on its face..
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Sound more likely the wrong settings for accel enrichment.
CRyan
Car: 1997 Nissan 240SX
Seishuku wrote:Sound more likely the wrong settings for accel enrichment.
THIS.
clever240sx
Car: Nissan 240sx
I know it is that! We've been messing with it trying to figure it out but nothing seems to be helping.
sydwayz315
Car: 92 240sx
i had the same problem with my rb running aem....the tuner i had adjusted the ignition timing and it corrected the problem...
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
There's also a common issue with the Nissan CAS and how many teeth it has. Supposedly you can use a mitsu one or AEM sells their own. I'll do some research on it for you, and post back.
playero_loko
Car: 1991 240sx
i'd be interested in knowing about that! going to central florida turbos for my tune within the next couple of weeks...
Return to “Engine Tuning”
