Slammed95S14 »
https://forums.nicoclub.com/slammed95s14-u101675.html
Sun Mar 29, 2009 5:15 pm
So my car at idle is doing 47 degrees of ADVANCE timing. If I take the bolt out for the CPS and adjust it to 10 degrees, the car doesn't idle very well at all, and it won't start when you turn it off and try to start it. The car runs pretty good at 47 degrees of advance, when you rev it, it goes all the way to 53 degrees. This s*** is scary. So obviously the car is parked.
Any help is greatly appreciated. Could my CPS be bad? I just re did the timing as well.
Modified by Slammed95S14 at 9:01 PM 3/29/2009
Modified by Slammed95S14 at 9:05 PM 3/29/2009
