sr20 {ac and power steering..}
boostedc10
Car: 89 240sx
i know u can use the twin cam ac compressor and power steering pump on the sr20 but has anyone tried the parts off the single cam? i just have one liyn round so i thought i could save some money lol
duffman1278
Car: 89 240sx Hatch, the wildcats!
people probably have tried it but probably doesn't work. I guess you can try it out and make a bracket to mount it to the sr. try it and if it works make a write up of it.
jongonzoS13az
Car: 90 240sx
im wondering if you could also use the american non turbo sr parts as well?
Hijacker
Car: '92 240sx Convertible
'94 F-150
no. american SR is FWD, so the AC and PS pump are different
jongonzoS13az
Car: 90 240sx
damn your right. thanks
fregisr
Car: 240sx 1990
for power steering it can be done. I did it on mine. You have to bend the lines. becarefull bending it too hard as you can break the lines. I bent mine towards the front of the car and then back
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Bending hardlines FTL. Hairline cracks will be evident in PS Leaks.
Emperor_Tha
will the dohc line work on the sr power steering pump? havnt installed mine yet.
fregisr
Car: 240sx 1990
Emperor_Tha wrote:will the dohc line work on the sr power steering pump? havnt installed mine yet.
if you have a dohc lines, then you're good to go. Both sohc and dohc bolts in the sr pump. The only problem with the sohc is the location of the lines.
redtop91 wrote:Bending hardlines FTL. Hairline cracks will be evident in PS Leaks.
I know about 4 people that has bent the line including my self and haven't had one problem a bit with any leaks
Emperor_Tha
ok thank you
