Louprint »
https://forums.nicoclub.com/louprint-u267559.html
Mon Jan 09, 2017 10:13 pm
Hey everyone,
I have an 89 240sx hatch with an sr20det red top that has a horrible misfire/running very rough for a while now.
I thought it was wiring related so I purchased a whole new wiring specialties harness and no change. It has good compression across the board (~145psi)
Changed spark plugs, made sure the CAS and the timing was perfect. It was perfect, no vacuum leaks, thought it was a bad coil pack or injector, so I replaced all injectors and tested coilpack with my buddies, but no change. Tried his ECU as well, no change.
The rough running started and progressively got worse. It is undrivable and the motor shakes it misfires so bad. Minimal exhaust smoke but does pop ALOT
Could it be the head gasket failed and the cylinders are leaking into each other? Really at a loss here thanks
