Sr20 240 top speed?
djs87
Car: 1993 Nissan 240sx Fastback
Just wondering, and yes Ive looked all over the place. Stock sr20 red or black top in a 240...what does it top out at?
argento
Car: 240sx
the sr has the same rev-limiter as the ka, 4th and 5th gear. so its the same 180kph/115mph
Dori Dori
Car: Cars of course
Well, it's not the rev-limiter that causes the speed cut. The ECU will pull fuel when the speed sensor sees 115.
Morph
Car: 91 Sr Powered Coupe
argento wrote:the sr has the same rev-limiter as the ka, 4th and 5th gear. so its the same 180kph/115mph
Im gonna take a wild stab and say that he wanted to know the engines top speed. I've seen a video on 1 hitting 170+
argento
Car: 240sx
Morph wrote: Im gonna take a wild stab and say that he wanted to know the engines top speed. I've seen a video on 1 hitting 170+
yea i saw that too, sweet video. but it was highly modified. so there you go, unless you get rid of the ecu fuel cut off, 115, or like morph was sayin 170+
djs87
good stab, because thats actually what I wanted to know...
wildacexxx
Car: 2002 Q45 nav sport
170 sounds like they changed the gearing. on stock gearing and everything i think that sr are gear limitied to 150 or something around there. 170 is a lil high and might require a gear change of some kind either in the diff, bigger wheels or transmission.
Dori Dori
Car: Cars of course
With 235/45/17 tires and a 7600rpm redline, the theoretical top speed for a 240 is 184.78mph - if my gearing info is correct which I'm 99.3% sure it is (5th=0.759 and final=4.083).
f150intally
Dori Dori wrote:With 235/45/17 tires and a 7600rpm redline, the theoretical top speed for a 240 is 184.78mph - if my gearing info is correct which I'm 99.3% sure it is (5th=0.759 and final=4.083).
ding, ding - we have a winner. There are several online calculators to determine the top speed of the car.
Plus it doesn't take as much power as one might think. A friend of mine has a bonestock 350z (287hp) and as gone over 160mph in it. Sure your sr would need some mods but not as much as one might think.
djs87
so with gearing it can it 185...what kind of power would you think the car would need to hit 185? Also a buddy of mine says his 6spd trans am ws6 can hit 180 w/o a limiter. Is the 240 gearing really that much wider to be able to reach that speed in 5th?
Dori Dori
Car: Cars of course
Stock gearing w/ those tires is 185. I know nothing about the gearing of a ws6 so I cannot comment. As for max top-end to power ratio in a 240, I have no idea since I don't drive that fast.
elgarvo616
Car: 1995 240sx aka sweet thang
i dont think i would want to go that fast in my 240...
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
stock gearing and stock 195/60/15 tires gives a 174mph @ 7500rpm. Ive personally had mine up to 160 before a coupler blew a hole in it and still had enough rpm to go.
TogueDrifter
Car: 91 B13 SER
I believe the speed limiter is at 120-125. I hit mine the other night. it was more than my Ka did!
starkos14
Car: s14 R33*, 99 gs300(2jz-gte soon)
ive taken mine up to about 130 a few times with the s13 blacktop, then the speed limiter kicks in. theres a spot near me on the highway thats always empty and clearly visble if there are any cops around. when it completely clear, the sr gets me to top out quick
Blown240sx
Car: 1996 240sx
Yea mine usually hits the speed limiter at 130 cause my speedo goes to the bottom of the cluster way after 115. Kinda scary at first when you hit it lol
DrifterProdigy85
i remember having my HUD and trying to top the car out. The HUD stopped at 125mph but the car kept on pulling. It pissed me off since the digital stops at such a low speed untill i took a Silvia Speedo and converted it to 180mph. It reads within 1 mph of a cop speed trap. Gauge read 60 when my ticket of going 59.6 in a 40 said so.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I remember less than a year ago someone had their S13 up over 170mph at an airstrip with a mildly modded s13 SR (less than 300whp).
DrifterProdigy85
its definitly doable. I went 160 using the T25 then a coupler blew out. Car was still pulling untill the coupler blew.
corey240
Car: 1993 Nissan 240SX Base Drift Machine
yea
