sr20 1/4 time
hungryjoseph
Car: s13 with rb25 and s13 with s14sr20
i'm just curious... can i run mid 12's on the 1/4 mile with 15psi? (s14 sr on a 89 s13) with a garet turbo manifold, front mount, bov, and 3inch turboback? if not then what else can i do bolt-on wise?
boost_creep
Car: 92 sr powered coupe,06 Spec V
t25 or t28?
low 13s is very possible with a t25,so id say high 12s is possible with the t28.
hungryjoseph
its a t28. what can i do to get that extra .5 in? greddy inake manifold help that much?
Rosco
Car: 91' SR'ed Hatch
Get some TIRES......You can't beat traction..
hungryjoseph
haha anything else i can do besides tires? motor-wise sorry forgot to mention that
adrianfromthecastle
Car: 1992 Nissan 240sx
dont fill the tank to full
kamikazestorm420
hungryjoseph wrote:haha anything else i can do besides tires? motor-wise sorry forgot to mention that
pulleys, lighter flywheel, drive shaft.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
make it so the only thing in the car is the driver seat, dash, and center console.
R6_240sx
Car: 1997 240SX LE, 2004 YZF-R6, 1980 Celica GT
LSD, weight reduction (smaller battery, gas tank, YOU), some slicks, smaller pulleys, aluminum driveshaft, racing fuel. Practice on ur 1/4 mile .
PowerGrid06
Car: 92TT 300zx
wa-chiss wrote:make it so the only thing in the car is the driver seat, dash, and center console.
haha. Yep that helps
I dont think you can predict 1/4 time with engine mods. Tires are realy important. When i went to the track the first time i did was 16.7 because i lost traction the next time i did a 16.1. (stoke ka)
hungryjoseph
ohhhhhhh... i have an aluminam driveshaft and lightened flywheel, but i never really payed attention to tires all that much...
boj240
Car: 93 hatch sr
bboyp1ng wrote:LSD, weight reduction (smaller battery, gas tank, YOU), some slicks, smaller pulleys, aluminum driveshaft, racing fuel. Practice on ur 1/4 mile .
nuff said. you get the
hungryjoseph
thanks guys!
da40
Car: 1995 SE 240sx
hungryjoseph wrote:its a t28. what can i do to get that extra .5 in? greddy inake manifold help that much?
u can have all the bolt ons in the world but if ur a $hity driver u wont run anything better then a 16 haha!!
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
da40 wrote:u can have all the bolt ons in the world but if ur a $hity driver u wont run anything better then a 16 haha!!
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
let me know how that works out, I have a very similar setup (S14SR20DET powered S13 hatch). I'm running 13lbs of boost, putting down ~260hp to the wheels.
I did all the underdrive pulley's, S14 FMIC, S15 T28, greddy dump, 3inch all the way back exhaust, exedy stage 2 puck clutch..etc mods.
I have VLSD and 255 Toyo T1-R's keeping that to the ground in the rear.
Ive only been to the 1/4 mile track to watch, once I saw a redtop S13 do low 13's on 17lbs of boost (but his starts were slow).
hungryjoseph
right now, i AM a ****ty driver, but all this gives me something to look foward to when i CAN drive stick well...
hungryjoseph
since ur running around the same, if u ever go let me know how u do... i probably wont be at the 1/4 till spring break or so.... i need to get the car running again... might need a new long block cus the tip of the spark plug fel into the cylander... i dotn know if theres any piston damage but all the labor costs to chek that and get a new headgasket or w/e... might as well get a long block
lrb_2000
Car: '91 Nissan KA-T hatch
Alright,
A friend of mine has a Redtop SR20 with FMIC, 550cc injectors, T28 GTI-R turbo, 14psi, and ran a 11.9 1/4 on drag radials, and a 12.3 on street tires..
hungryjoseph
wow... nice... s13? stripped?
R6_240sx
lrb_2000 wrote:Alright,
Damn that's hella fast.
hungryjoseph
sigh... i'll dream of that... or dream of a running car... which one to dream of first? LOL
hungryjoseph
seems like im always dreaming with this car
SR20Essex
hungryjoseph wrote:since ur running around the same, if u ever go let me know how u do... i probably wont be at the 1/4 till spring break or so.... i need to get the car running again... might need a new long block cus the tip of the spark plug fel into the cylander... i dotn know if theres any piston damage but all the labor costs to chek that and get a new headgasket or w/e... might as well get a long block
I had that same problem; notice the plug on the right in this picture.
Honestly though, I don't think it did any damage. I knew the second it happend because the car ran like complete garbage as soon as it would reach boost, but after I swapped out plugs it ran fine.
hungryjoseph
omg.... you shine light into my world.... that plug looks EXACTLY like mine... i need a new hadgasket too.. but wut could cause the tip to fall of like that
R6_240sx
Faulty spark plug or u driving the crap out of ur car
silent dave
Car: 05 LGT
91 240sx
bboyp1ng wrote:Faulty spark plug or u driving the crap out of ur car
and by driving the crap out of the car he means knock.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
15psi with T28. First off is making reliable power. 480 or 550 injectors, Z32 MAF and ECU tune. 256 or 264 cams will help. As for running 12's. Youll need some drag radials or slicks to achieve a 1.6-1.8 60ft. Its not too hard with practice.
