SR wont stay running.
dino619
Car: 240sx
I can get it to turn over,but then it just shakes and dies after 2 seconds.the fuel cutoff switch is working in off and on? i have a stock fuel pump.any help guys.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Possible fuel delivery problem. An easy way to test the fuel pump and filter is to disconnect the fuel hose from the top of the fuel filter and insert a long length of spare hose into the top of the fuel filter with the other end draped over the fender going into a catch can placed on the ground. Now turn the ignition key to the run position but DO NOT START THE ENGINE. You should see fuel going into the can at a good rate for several seconds.
S13driftproject
Car: 1991 Nissan 240sx hatch
I had this problem when I first got my SR. It turned out to be that a vacum line was leaking from improper sealing.
