SR wont Start
ZOMG.SR20
Car: 1990 s13
it cranks and cranks but wont start
has fuelhas sparkis all in time
has gas and battery is charged im at wits end here
Blown240sx
Car: 1996 240sx
CAS timing must be off. Have you change anything recently? Just swapped? background of problem is needed...
ZOMG.SR20
Car: 1990 s13
its a new swap and the timing is spot on
the compression is 170psi across the board
Blown240sx
Car: 1996 240sx
Your base timing might be right but the igntion can be 180 out. Does it pop or sputter sometimes?
ZOMG.SR20
Car: 1990 s13
how can i make it not 180 degrees off? and no doent make any noises except turn turn turn
ZOMG.SR20
Car: 1990 s13
hmm i stumped everyone
Blown240sx
Car: 1996 240sx
recheck the ignition timing. Set to TDC remove valve cover and pull CAS and reset.
ZOMG.SR20
Car: 1990 s13
whats the proper way to set ignition timing . i heard you were suppose to ground a wire out or something cause the CAS is positioned right and everything is in time
Blown240sx
Car: 1996 240sx
If your getting spark, fuel, you might check maf voltage. But I always double and triple check timing.
zach-Ka
Car: 1990 240sx (SR)
When you say it has spark, Did you check the voltage for the coils or did you check the plugs?
http://www.frsport.com/How-To-....html
ZOMG.SR20
Car: 1990 s13
how am i supposed to use a timing light with no park plug wires?
zach-Ka
I never used a timing light and it worked great. But supposedly you can just use wires going to the coil packs. Or you can take the coil pack out, hook up a normal plug wire to it and then to the plug itself. I didn't do it but this is what I read.
ZOMG.SR20
Car: 1990 s13
i used the loopy thing in the back and im pretty sure my timing is off by a tooth
zach-Ka
The loopy thing in the back? Can you elaborate?
ZOMG.SR20
Car: 1990 s13
ok so i took the valve cover off and it was off by a tooth now it turns and turns and fires once the dies as i keep turning i over
ZOMG.SR20
Car: 1990 s13
Blown240sx wrote:Your base timing might be right but the igntion can be 180 out. Does it pop or sputter sometimes?
its now doing this sort of
ZOMG.SR20
Car: 1990 s13
HELP!!!!!!!
ZOMG.SR20
Car: 1990 s13
zach-Ka wrote:When you say it has spark, Did you check the voltage for the coils or did you check the plugs?
idid that now it sort of sputters when starting
ZOMG.SR20
Car: 1990 s13
PLEASE SR GODS PLEASE HELP
vr446
Car: S13
try double checking the wiring of your ignitor chip if you are using a different chip other than the SR onei'd also check clean the plugs again depending on how badly you may have flooded it...they could be soaked with fuel
fear@loathing
Car: 1990 s13 240sx hatch
Ok i had same problem engine would turn turn turn but no dice
so i took out the first spark plug stuck a metal rod in there (so its on the piston) then i set to TDC i knew it was TDC cuz the rod was way up high
then took off the valve cover took out the CAS
ok now the important part the look at your CAS there should be a little indented line near the black part then line up the first dot on the shaft to the line
put it back in carfully trying not to twist it and the second dot on the CAS shaft should turn and line up with the indented line near the black part
ZOMG.SR20
Car: 1990 s13
fear@loathing wrote:Ok i had same problem engine would turn turn turn but no dice
i did that already no dice
jazz4890
Car: 1991 Nissan 240sx
so you checked every single coil pack to make sure its getting spark? this is what happend to mine it would crank and crank but no start try switching the fuel lines from the fuel filter to the nipple closest to back of the motor and take the fuel line coming off of the hardline from the bottom of the car and put it on your fuel pressure regulator.
Blown240sx
Car: 1996 240sx
jazz4890 wrote:so you checked every single coil pack to make sure its getting spark? this is what happend to mine it would crank and crank but no start try switching the fuel lines from the fuel filter to the nipple closest to back of the motor and take the fuel line coming off of the hardline from the bottom of the car and put it on your fuel pressure regulator.
Yea fuel lines being backwards will cause a no start situation. My buddies SR had this issue. He fought with it for a week until they figured it out.
Also if its not that and is sputtering on start. Recheck ignition timing.
ZOMG.SR20
Car: 1990 s13
you cant check ignition timing on a non running car and i dont know how to do it with a multimeter
Blown240sx
Car: 1996 240sx
Im talking about the CAS timing (alignment). Doesnt have to run to set the CAS.
ZOMG.SR20
Car: 1990 s13
fixed timing after all this it was bad gas 8 month old gas
