Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Sat Aug 07, 2004 8:59 am
Lets see, I think you can do some tests to make sure it is your relay, did you check the fuel pump fuse? Just little things like that, I'm sure you don't have to take it to a shop. What about the wiring that goes by the battery. You sure you got those spliced and connected properly? I'm just saying because i"ve done like 7 S13 SR Swaps into S13's and the first two I had similar problems and it's due to improper wiring. The last 5 started on the first try and there isn't a lot of things that could go wrong. Just the wiring by the front of the car is the most important set that you have to rewire because some of the wires do not line up if you didn't already know that. If everything is correct, just hardwire the fuel pump to the battery to see if that works, if it does and you can't get the original relay to run the fuel pump, then just custom your own relay to run the pump, if you're not sure on how to do that, just let me know.
