240 Doubledrive »
https://forums.nicoclub.com/240-doubledrive-u17114.html
Sun Feb 06, 2005 2:41 pm
Hi guys, i need some help and any would be greatly appreciated. I did an SR20DET swap a few months back and then wanted to go faster so I started with some upgrades. I put in Nismo 555cc injectors, Z32 MAF, Front mount intercooler, HKS SSQV bov and an Apexi S-afc. I finally finished with all of that today and tried to start it. Baby started on first turn. Jumpy idle but was working fine when engine was cold. I shut it down to go grab something in the house and came back and tried to start it again... Did start, but black smoke out of exhaust...?? barely holding on at about 200-300RPMs. When you try to give it some gas it goes up to around 2k and then bogs and dies. I did reset the S-afc to factory defaults.Here are some things i noticed but dont know if it should be like this... 1) when you blow into the bov it lets air through. Normal????2) The injectors didn't get sucked into the rail like the stock ones. Normal??3) The MAF plug had 2 grounds. I wired them together. Is this right?
Once again any help would be appreciated THANKS TONS!!!
