Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Thu Mar 16, 2006 8:21 am
Ok, more info here. So does it click when you turn the ignition? Have you tried jumping it? After so many attempts to get it to run, I'm sure the battery, if not fully charged, would wear down.
If your car was running fine with the SR and after a fuel pump swap, it no longer fires, wouldn't that be a bit obvious... unless it worked fine for a few days, maybe even a few minutes then died and won't fire again after the new pump... but that bit of detail is not included so I'm assuming after the fuel pump swap the car no longer fires.
Check the fuel pump and jump/charge/buy new battery, to see if that helps with the cranking.
