chicos240 »
https://forums.nicoclub.com/chicos240-u20799.html
Tue Dec 26, 2006 10:53 am
Look at these 2 diagrams.
As you can see the Neutral switch or clutch switch needs to be set or the ignition will not even send the signal to the starter.SO if you do not hear the relays in the fuse box clicking then you dont those things jumpered correctly.If you do hear clicking, but notthing cranks, check your GROUNDS on engine. Then gently tap starter with a hammer, dont hit, tap it, sometimes it gets stuck. Third, you could have a bad starter.
Modified by chicos240 at 3:31 PM 12/28/2006
