SR won't start, white smoke came out of exhaust
JimmyJames1
Like the title says, my SR won't start. I was on the highway and it was bogging just a little, so I pulled over to just check the fluids. Everything looked fine, but when i went to start it again, the motor cranked but wouldn't fire up. The first two times I cranked, white smoke came out of the exhaust. Intercooler piping looks good, no leaks as far as we can tell. I think I'm burning oil. BTW, S13 SR in S14. Any suggestions? Thakns
fantabulous
Car: s14
pull off the head and check the head gasket.
JimmyJames1
Tried to start it up today without doing anything at all (it's been sitting in my driveway since I had it towed yesterday) before doing anything at all. To my surprise, it started up. I had to give it some gas to get it going at first, and white smoke came out of the exhaust once again, but it started and seems to be running fine. Now when I start it I don't need to give it any gas, it starts like normal, no white smoke or anything. Just thoguht I'd share in case anyone else is having a similar problem.
nismostate
Car: all sorts of motorsports
might as well do a compression test or a leak down test. sounds kinda weird that your motor died all of a sudden. retighten your intercooler pipings also.
dj_lennon_franz
Car: 1992 240sx
JimmyJames1 wrote:Tried to start it up today without doing anything at all (it's been sitting in my driveway since I had it towed yesterday) before doing anything at all. To my surprise, it started up. I had to give it some gas to get it going at first, and white smoke came out of the exhaust once again, but it started and seems to be running fine. Now when I start it I don't need to give it any gas, it starts like normal, no white smoke or anything. Just thoguht I'd share in case anyone else is having a similar problem.
my SR has been doing this for a while now...no one has been able to give me a straight answer as to the cause of it...i doubt its the head gasget given the car doesnt over heat (or come ne where near it)...im guessing its either something to do with the turbo or the starter
ericherm1
Car: 1997 Pickup XE 2.4L 4x4 Single cab short box
1991 BNR32 Skyline GTR
1991 240sx SE SR20DET + S13 Silvia Front end swap (Sold)
Could it be the oil or water seals in the turbo going out?
