SR won't start!!!!!!!!!!!!
cheez80
Car: percussion =D
i've searched and didn't really come up with a suitable solution.
anyway, i did a clutch job by pulling the motor. at the same time, i relocated the wiring harness in the passenger's side fender well into the engine bay by taking it apart from the inside. i also had james at g-dimension rebuild the main engine harness.
everything's bolted back together, but the thing won't start. i've double checked all the plugs; everything seems connected and grounded, etc. the fuel pump doesn't prime anymore. when i crank it, i hear a clicking from the fuse panel area in the driver's side kick panel. i had a friend knock the starter around with a broom, but same thing happened. i also made sure the clutch interlock (is that what it's called?) is connected.
anybody have any idea what could be wrong?
bdrifta
Car: 1992 Nissan 240sx sr20det
check the wires under the steering column...
my friend had the same problem, and he found out that his starter wire had been pinched by something and was grounding out. just check if the starter wire, ignition, all those are getting power when there supposed to.
