sr with engine damage still fast
s13sr20chris
nice headline huh?well i found out why my turbo sounds so good.
blowby...
13psi with some leaky rings on cyl 4 makes for a nice wssssst noise coming out the breather filter. cyl 1 155cyl 2 163cyl 3 162cyl 4 95
still fast and just a little bit of rough idle. the guy i got it from said the turbo has been loud like that for about a year. it just might stay that way till i have the money to rering her. i think i can rering it in the car in one day. thats with all my tools, in my own bay, with my own lift. what do you guys think?
Cyberkreig
Car: 1993 Nissan 240SX SR
compression leaking past the rings is called blow down
Try puting a cap full of actual dyno bone oil down in cyl #4. Let it sit over night, longer if possible. It will smoke when you start it but in many cases this can help re-seat the rings.
the other option scares many people but i have done it personal and it has worked.
run 1qt 2cycle engine oil in a full tank of gas. iirc this is about a 100:1 mixture, as the oil burns it lubricates, this is good for every type of motor, tho horrible for emissions. Best of luck.
s13sr20chris
dyno bone oil? i put a little bit of motor oil down there for the wet compression test. by the way with oil in the cyl it pulled a 120 on no 4. what is dyno bone oil? is that a reference to conventional oil aka dino oil?
the questino is...do i just get some se-r rings and slap them in as fast as i can on a saturday or buy bearings, t-chain, tensioners, guides, valve stem seals, etc. heck i could swing the head by my father in law for a quick port+polish? i am thinking that a gasket set, rings, and rod bearings(hope the mains are ok) could be less than $400. anyone selling pistons with rings for cheap(stock bore size)? j/k
