ibreakstuff »
https://forums.nicoclub.com/ibreakstuff-u76627.html
Thu Sep 20, 2007 12:58 pm
All you have left is the Starter power, Main power, and the alternator. Make sure that you ground all loose blacks wires and that's it! My truck had a cable speedo, no tach, and no AC so if you want those options you will still have a few wires to hook up.
Transmission wires:
Green/White,Green/Blue = Reverse (I have no reverse light so I did not hook this up.)
Green/Orange,Black = Neutral safety
Green,Green = Speed sense
If you want to get rid of your clutch inhibit and have a JDM style setup where the truck only starts in neutral:
Cut the Light Green on the starter relay switch.(Yours will be attached to the passenger side of the engine compartment.)
Splice in the Green/Orange from the transmission. Be sure the corresponding ground wire is also hooked up. Double and triple check the operation of this switch before you put your truck on the road.
