toledo240 »
https://forums.nicoclub.com/toledo240-u10281.html
Wed Jul 07, 2004 2:44 am
you cant use the upper wire harness. You can use some of the plugs, which are recommended.i know for the second pc that is where your ecu goes and the plug at the end goes to the dash.You can kinda tell which goes where just by placing the harness across the engine and see what plugs into where. Remember that the ecu in silvia's are on the left side of the car since its right hand drive.So it will look odd why some wires and real long and and notYou can which i would recommend is get the aire schamatic of the wire harness saying which wire goes where and try to piece it out. I cant think of the website that has it. You best bet is to go on bay and look for the guy that can wire your ka24 harness to your cut harness.
