jdm_master_X wrote:the car just clicks. it has spark and fuel because i tested the injectors, plugs, and major connectors and they are all getting the correct amounts of voltage. all the major ground wires to the chassis were on and were also getting voltage. everything from the last car was swapped into this car so nothing was missing.
i went to look at it again, and my wiring was up to par. color for color and everything. but im going to double check to see that they didnt come lose or frayed.
what i wanted to know was what that gray 8-pin male connector was for.
have you checked your fuses. also if you are gettting spark and fuel something should be happening other than clicking because there going to be combustion. are any of your lights not working? check your fuses. you also didnt say that you checked your ground.
I am having problems believeing it is an electrical issue because you have said your car has fuel and spark but nothing else. you said the starter is engaging then all of your main wiring to get the car running should be fine. Is you IACV plug correct?
if you think it will work switching the connector from the first car give it a shot, but make sure you have enought wire and note changes that you make.
