SR was starting fine, relocated battery, won't crank =(
exode
Car: 90' 240 w/ 400hp SR20DET
Hey all,
My motor would start fine, I installed my coldpipe and used the summit kit to relocate my battery to my trunk. I could turn everything on fine, battery was giving right power, but then when i cranked it it clicked a bunch of times and did a brief, very weak crank and then everything in the dash went dead. Now I have no power.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Sounds like your grounding is messed up. Double check your grounds, and then find the blown fuse or relay.
exode
what fuse would be blown? or relay
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
I'm having the same problems with my S14. I keep blowing my 100amp fusible link. The moment I give power, the fuse pops. The engine cranks, but no accessories or lights work. I'm going to go thru it this weekend. Again.
