littlemilla3 »
https://forums.nicoclub.com/littlemilla3-u10700.html
Tue Apr 27, 2004 3:41 pm
Well, I have an s13 with an SR20 and I want to upgrade from my S14 turbo. I'd like to get the GT25r or a t3/t4 50 trim. Here is the problem: I want only an external wastegate, no internals, but I have a JIC tubular equal length manifold with a t25 flange.
Here are my potential set ups:
T3/T4 50 trim: cut off t25 flange from manifold and weld on t3 flange and a wastegate tube.
GT25r: keep t25 flange and have shop weld on a wastegate tube, and weld wastegate door shut on turbo; take out the flapper door and have a custom o2 housing with the wastegate directly after the wastegate passage in the turbo. Get what i'm saying?
Anyways, I think I would like to go with the T3/T4 route. If you have any suggestions or concerns, please post here. What set up do you think would be better?
