USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Fri Dec 12, 2003 7:33 am
I did a big write up earlier on this. Basically it boils down to this...
Yes the SR o2 housing will work on the CA turbo and you can then use an unmodified SR downpipe.... BUT!!!
The SR o2 housing is about an inch and a half longer than the CA o2 housing. So it will hang a bit lower from the bottom of the car than it would if you did CA/Modded SR downpipe combo.
I bought a stock SR o2 housing for this purpose, but I never did use it. If you want one to look at or try yourself, 25 bucks to your door it is!
Joe
