sr transmission problem.
emo
Car: s14b & gs300
well my transmission is leaking gear fluid from the transmission on the end of where the driveshaft and transmission meet. i pulled the old output seal and replaced it. the seal was torn. i put the new one in and put everything back in, in reverse order and when i put more gear fluid in there the gear fluid still leaked out the same spot. im not sure whats going on. any advise on what to do? is there another seaal or what not in the transmission that could be torn also that is casing it to leak in that area?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I don't know if this will help but is the fluid level correct? Could having too much fluid in the system cause this?
emo
Car: s14b & gs300
i think ur correct bro. thanks i really appreciate the input. i think i have to drain some out.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I would check the shifter plate. That's where mine is leaking.
tercel drifter
Car: sr20det s13
2.4L if im correct
