SR Transmission Bolts
NiSilS14
Car: 95 240sx
tried seraching, but didnt find too much. Are there any transmission bolts off of other cars that are interchangable? My motor came without the transmission,clutch, or flywheel bolts.....how lame. The clutch from the maximas are able to go on the Sr. So I am assuming the clutch bolts would work. searched that SE-R sentra flywheel bolts will work?
msaskin
Car: cars, computers, skiing, mountain biking
Did you call the dealership and see if they carry them?
If not, you're just looking for M10x1.5 (iirc) bolts, just make sure you get the right grade, and I'm not sure on length.
~matt
f150intally
i think it tells you in the FSM exactly the length of the transmission bolts. i went through the same thing with my swap. just bought my bolts from pep boys, grade 8.
Let me save you the trouble....damn i'm a nice guy :)
RobDET
Car: Cars
It's a red x for me :D
f150intally
yeah, my server has been flaking out, should be up now.
RobDET
Car: Cars
sweeeet
mynismo
its not 10x1.5... its 10x1.75. i just went through hell on mine too :)
the smaller ones are 8x1.25 i believe...
there are 11 bolts + 2 starter bolts.
f150intally
11 including the starter bolts, right? in the diagram that is the case.
unfrgivn
Or if you're me, 10 because I'm too lazy to buy the last bolt. Eh saftey factor of 10 is more than good enough for me. At least the transmission isn't held on by duct tape like many things in my car.
mynismo
nope... 11 + 2 starter bolts. 13 all together.
unfrgivn
mynismo wrote:nope... 11 + 2 starter bolts. 13 all together.
Well then I have 12
NiSilS14
Car: 95 240sx
Ok cool, i got the transmission bolt info down. So will the clutch bolts off the maxima works right?, and the Sentra SE-R flywheel will work right? Thanks for the help guys!
