sr transmission problem
DriftSpec240
Car: 95 240
well first of all my transmission is a 5sp and when its in neu. its in reverse, and i can only get into 1st and 2nd and when i let the clutch out the engine starts to die
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Most likely the roll pin in the striker rod is broken.
DriftSpec240
Car: 95 240
so should i just replace the transmission
FRoSt415
Car: s13 240sx
go to the junkyard or dealership and ask for the roll pin. buy it and with a wrench or deep end socket remove the old one. its under the trannmision fork. but when you replace make sure you lube it up with grease. i didnt do that when i changed my clutch. i dindt even check it and a week later it broke. i might have a video for you give me a few days.
