Sr transmission on ka
Arm4nii
ok so i have a ka34 motor and a sr transmission with a ka bell housing. And i know that it will work with my motor i just need to know what clutch and fly wheel i willl need to use with the transmission
centralcoaster33
Car: 1997 Nissan 240SX #5
You basically converted your SR transmission to a KA transmission with the bellhousing. Now you have a KA motor and a KA transmission, so you need a KA clutch and flywheel. That's it, nothing special or weird for your car. You need a regular OEM flywheel for your engine, or a lightweight aftermarket one. You need a standard clutch kit for your engine, or a grippier aftermarket one. Just search for 240sx flywheel or 240sx clutch kit and those will fit.
Arm4nii
centralcoaster33 wrote:You basically converted your SR transmission to a KA transmission with the bellhousing. Now you have a KA motor and a KA transmission, so you need a KA clutch and flywheel. That's it, nothing special or weird for your car. You need a regular OEM flywheel for your engine, or a lightweight aftermarket one. You need a standard clutch kit for your engine, or a grippier aftermarket one. Just search for 240sx flywheel or 240sx clutch kit and those will fit.
Alright thanks man
