SR transmission noise - help please!
Deadrodent
Car: 1992 240sx hatchback
hey everyone...seems i have another problem with my car. the transmission is now making a very noticeable noise and i'm having a difficult time diagnosing the problem.
the noise happens in all gears with the clutch engaged and the car moving.
it first started off as a whine but now has been replaced with a loud growl/blowing wind sort of noise. (when i accel quickly the transmission noise is louder than the engine)
i have a few ideas but i'd like to see what you guys think. i think it could either be the throwout bearing destroying itself or my transmission's gears destroying themselves (maybe because of low fluid? but why would the sound get worse unless i have a fluid leak in the transmission?)
baaaaah someone please help! thanks in advance!
NotanotherSR240
Car: 89 SR20det 240SX
Deadrodent wrote:hey everyone...seems i have another problem with my car. the transmission is now making a very noticeable noise and i'm having a difficult time diagnosing the problem.
I just got the same problem so someone please help.
silvia-junkie
Car: s14 kouki
im thinking throwout bering once a bearing goes it will only get worse and quick. but check your fluid hows the level and see if there is any metal in it there should be a magnet on the drain plug
Deadrodent
the sound gets louder in 4th...thinking output bearings?
fullthrtl_tech
Car: 93 240sx
most likely because thats the best way to single it out is to see if the noise changes in direct drive.
