auto alchemist »
https://forums.nicoclub.com/auto-alchemist-u25643.html
Tue Mar 11, 2008 7:00 am
ok i went to bolt the transmission up to my sr so we can drop it in the car, and it wont go, so i stuck my driveshaft in put it in gear and turned the drive shaft while trying to get the transmission to go in and nothing, so i loosen up my pressure plate and put my clutch alignment tool back in and keep sliding it in and out while im tighening the pressure plate back down to make sure it stays aligned, try to slide the transmission in and still nothing, the end of the shaft slides in and i had a jack under the transmission and it was perfectly lined up with the motor but i just can get the splines to line up or something, is there something im missing here? or some kind of trick to getting it in?
ive put trannys on my KA before so i know what im doing but ive never had this problem before
