SR transmission drain plug = KA transmission drain plug???
pgt892
Car: 1997 240SX
I went to change out my transmission fluid with some Amsoil and my transmission drain plug is trashed! Looks like someone took a chisel to it. I am going to do the same to get it off but I would like to get a new drain plug. Can I just go down to nissan and get a drain plug for a KA transmission? Does it matter if it is a S13 or S14 transmission or are they all the same? I would love this info ASAP so I can get this nasty fluid out and the good stuff in! Thanks in advance, Alex.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Well since the gearboxes are interchangable i would certainly assume they are the same :P
pgt892
Car: 1997 240SX
Thanks.
nismostate
Car: all sorts of motorsports
they are the same btw. had to use both my drain and fill plugs off of the DOHC KA transmission. my sr one's were toast! had to jam a small *** socket in both to get it out. i was literlly in the air using all my body mass to break that damn thing loose. probably stayed in the air for at least a min or two.
pgt892
Car: 1997 240SX
I feel ya. My SR fill plug must have been put on with on impact wrench or they used loctite or something. I can't seem to get the thing off. I am contemplating buying an electric impact wrench for just such an occasion.
nismostate
have you got it loose yet?? if not, the impact wrench might not work. i got to the point where the socket wouldn't grip on there. i had to hammer a really small socket in there. hope you have craftsman cuz my socket didn't scratch at all.
