Actually, it's boost threshold; not turbo lag.
micahjan, get a free flowing exhaust/downpipe and you will build boost quicker. Also, in some cases a boost controller can assist as well.
This is good info for some of you turbo n00bs, especially the KA guys looking to go to a SR. A turbo gives good power and torque, but comes with a price. Boost threshold and turbo lag. Also the SR has less displacement and a lower compression ratio, which gives the engine no low end grunt. A lot of Subaru guys that traded in their 2.5rs's (for those that don't know, it's a 2.5 ltr 4cly w/ similar power/tourque characteristics of the KA, version of the Impreza) for WRX's were very unhappy with the lack of low end power. They didn't do their homework. A WRX is a 2.0ltr like the SR, but has an even lower compression ratio...8.0/1. The car feels like it has maybe 40-50hp or just really, really bad gearing before the turbo builds boost. If that doesn't sound appealing to some of you, and you've been pipe dreaming about about a SR swap and a bigger turbo, think about this as well. Generally, the bigger the turbo the worse the lag and spool up are.
