Movingviolation240 »
https://forums.nicoclub.com/movingviolation240-u104.html
Tue Sep 02, 2003 6:57 pm
The radiator is just so small that it heats up in a hurry. Plus the temp range on the stock temp gauge is so limited it has a pretty wide 'range' for 'normal'. The motor really isn't warmed up (even though it says it is) untill the thermostat opens up and starts letting coolent flow. Also a side note the oil will be like 3 or 4 min behind the coolent warming up so don't rev it too much untill you get that up to temp.
The water going through the turbo really dosn't cause it to heat up that much quicker. My NA KA did the same thing when I'd start it up, even in the middle of winter.
Bottom line though, don't worry about it, that's pretty much normal.
PaulOrlando, FL
