What?redtop91 wrote:I believe that 14 PSI is the SR T25's max duty cycle. I dunno for sure seeing as I cant get my AVCR hooked up for the life of me.
Speaking of... (OT btw). It dipped down to the low 40s the other morning and I let the car warm up for 10mins or so. I was pulling out to leave to take the woman to work and there was some traffic coming do I shifted to second and punched it. The car hauled ***! Back tires broke loose and the car was fishtailing and whatnot. And I have a vlsd. This was at 14psi on a T28. Craziness.rico05 wrote:I run my T25G @ 12psi just to be safe. No knock, and if I punch it in a low gear from 3-4k, it will break the tires loose. That means it is enough power for my needs.
it would be interesting to compare track times between the two, if you could get consistent enough results with eachfloat_6969 wrote:This reminds me of something I meant to bring up about the HLSD, since I've switched to it, it is MUCH harder to get the rear end loose. With the VLSD, it was pretty easy but the HLSD must put the power down more evenly. The positive side to it is that it doesn't fishtail nearly like a VLSD will. [/offtopic]
