SR swap with a/t transmission?
ImChrisLara
Car: 1991 240sx LE Fastback
is there any way to accomplish putting the KA auto transmission onto a SR20DET? because i had a 5 speed but i got tired of shifting so i bought an auto
Hijacker
Car: '92 240sx Convertible
'94 F-150
the trannies are not swappable between the cars. each car has a specific bolt pattern, and the bell house bolt patterns between a KA and SR are different. I believe that the SR bellhouse will bolt up to the KA gearbox, but I'm not sure to the accuracy on that.
ImChrisLara
thanks, i really apprechiate it. because i love a 5 just as much as the next guy but i just get too damn lazy on my way to school, one day i stayed in second all the way to school
Fish240
Car: 87 corolla gts
You can just get an automatic sr20det, a guy here has that
Spins
Car: spending too much money on my cars.
Yes you can get a sr20det with auto transmission. I have a 95blktop with auto transmission. they are only a few of us out there. and information for us is hard to find. I've had mine for almost a year now.
Neejay
Spins wrote:Yes you can get a sr20det with auto transmission. I have a 95blktop with auto transmission. they are only a few of us out there. and information for us is hard to find. I've had mine for almost a year now.
Do you have a BOV? How does it sound when you let off the throttle? Im gonna have an auto ca18, but Ive never heard a BOV on an auto. Do you like it overall?
Spins
No, I'm running the stock s14 recir. valve with a combination of a s13 intercooler with s14 piping. It you on it hard and let off you can hear a whoosh. But it's very quiet/steathly. I know it leaks alot but and probably slows down my spool time. But for now it works. I did install a non adjustable BOV once a bailey model from my friends turbo miata. These bov's don't leak at idle and you need one that doesnt. It vented and then I would here turbine stall or what ever it's called. So I didnt go with one of those. But I have read that the ball bearing turbo can take the turbo stall. But I don't want to risk damaging the turbo. With an auto you wont hear it between shifts only when you let off the gas.I love my auto. I have a leg injury and needed one. One of the drawbacks I see with my car is the timing control. Off the line if you floor it, apparently the ecu pulls timing so you loose some power. If your a little easier on the go pedal from a stop its quicker off the line. My car isnt super fast. It runs low 14's in the 1/4 mile at 10-11 psi on 18's. My mods are 3inch downpipe, resonated test pipe, megan catback. fuel pump,300zx fuel filter, cheapie boost controller, koyo rad,dual 10"fans, Q45 front brakes. And I still have my A/C, custom lines made.I would like to have more bottom end power. I think with some retuning of the ecu and a tq converter these would help out greatly. I don't know anything about the ca18. How much tq does this engine have? Being smaller displacement this will probably hurt you off the line.
