Sr Swap Wiring Whoes Pt.1
mikecef2
Car: 90' Nissan 240sx (SR20det)
Hey. .. . I'm very frustrated. I've spent the past 2 years building an SR to put it in as best to my ability and now it won't even crank over. Its a SOHC auto to manual SR swap. I followed the wiring guide from FRsport and I think it has some loop holes.
1. They say the fuel pump wiring is black and pink. It is on the KA plug but there is no black/pink wire on the SR harness. I only see a black/purple wire on the SR harness and I have no idea where it goes to.
2. I relocated the battery to the rear and everything seems to be fine because all my interior lights and gauges work.
3. The lower trans harness has a grey 2 wire plug that is black/yellow and white. This is for the starter S terminal. The chassis has a female plug that is also the same exact size color and same exact wire colors but because of the 5 speed swap, I did the loop for the neutral safety switch so i'm not sure if the starter is even connected right now.
I'm about to just say F*** it and just put a push button start in the car. Can anyone be of assistance in the issues of my no crank no start issue. ??
