SR Swap Wiring Question: 02 Sensor cut - is this my o2 sensor plug?
turblu
Ok guys... Im at the last of my Sr swap wiring details. I need to extend my o2 sensor but its cut at the o2 sensor (about a foot away from it). Im pretty sure this plug (pictured below)is the plug. I dont have the end that plugs into it for the o2 sensor. Should I cut the plug off and use quick-disconnect connectors? Also which wire connects to which plug?
Red: (brown Im assuming)Black: (black I'm assuming)White: (white Im assuming)
Am I correct here? Or am I totally wrong and this isnt even my o2 sensor wiring? The pics are down on frsports wiring diagram so this is making it harder for me to figure out.
turblu
bump for the morning techs
180fan
Car: 89 fastback
That's probably the o2 sensor wire. It comes off that main section with the plugs for the ignitor and other stuff around there right?
hmm what kind of o2 sensor is that you're holding up with the red, white and black? Usually it's two white for power/ground and black for signal.
turblu
yes Im pretty sure its the o2 sensor plug, but I dont know what the colors represent. So blk is signal and not ground?
turblu
N/M - Found this pic online-
