SR swap transmission questions......
Steve Lloyd
I know I swap my VSS from the KA to the SR transmission, but will the slave cylinder swap over?? Also, do I use the KA wiring harness for the transmission. I have the main engine harness in my living room(wife loves me ), but there is a sub harness on the transmission. My slave cylinder has a torn rubber boot and I would like to replace it any way and wanted to know if the one from the KA would work. Also, is the VSS the only sensor I need to swap over to the transmission.
Thanks, Steve
Blown240sx
Car: 1996 240sx
Slave cylinder will work yes and the SR lower harness is not needed the KA lower harness works.
