DRIFTMUNKY wrote:run shielded cable..solder and heat shrink it..don't use crimp connectors..its freaken easy to wire up..FR sport has a fool proof write up on the wiring
Just like he said. Don't you butt connectors, just use the MAF and O2 wiring from the KA harness to extend the Sr plugs. This is SUCH an easy swap. Any one that has a basic knowledge and can look at a diagram can do this. They even have all the wiring done for you. I would encourage you to try this yourself. Unless your really scared to.
