loudbay »
https://forums.nicoclub.com/loudbay-u12421.html
Thu Feb 12, 2004 6:51 pm
i did it by myself..... it took about 2 months, but i didn't have 100% of the parts sitting in my living room befor i started.... i checked out my c.c. statement, and (including the car) i've spent about $6700 (maybe even less!) and i've got it all! so if you can drive your 240 until you have 100% of the parts at your house, i say DIY. i probably only have 14 man hours of actual labor on the car, and that's for everything done to it so far.... (kyb gear climb struts, rsr springs, apexi gt spec exhaust 3.75", tubular header, hks 2540R, fmic, greddy int man, greddy oil pan custom pipes from projectnissan.com, 44000km redtop (yes really 44000km) apexi afc and avcr, apexi t.timer, m300 wideband 02 sensor with analog output to fool the stock ecu, upgraded ecu for z32 maf and 740s, 740s, z32 maf, homemade 3" intake, hks intake filter, z32 ignitor chip, new wiring harness, and s13 front end conversion-though still not painted, but installed... boost gauge, egt gauge and oil temp gauge, and sealed battery for the trunk.... so far the only things not installed are the intake manifold and the wideband 02 sensor, but those should be in by early next week... oh and a greddy front strut bar, and a no name rear strut bar.... i think that's it.... just some inspiration for the DIY guys....
