sr swap question!please help!
driftiteasy0113
Car: SR PIGNOOOZZZE
hey guys i am currently doing an sr swap in my sohc s13. i have searched and cant get a clear answer. the dash plug is different in the sohc than the dohc. am i going to have to splice the male and female sides of the plug to dohc? and also am i going to have to use a dohc cluster??lemmie know sr guru's!!
DuckyD
Car: 1995 240SX
As far as I know...
As long as you aren't HUD.You don't need to do anything with the dash harness.You just need a DOHC cluster which should plug right into existing wiring (no splicing or anything required).And you need to use the KA 5-speed Speed Sensor and put that in the SR transmission for your speedo to remain correct.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
DuckyD wrote:As far as I know...
^ Make sure that the KA 5-Spd sensor is from a 91-94 DOHC.
Steady_One_S13
Btw, there's a Nissan meet in the eastside of town, this Sunday Sept. 27.Hit it up if you can. Spread the word.zer...age=4
Sorry for the thread-jack.
Justin35ll
Car: s13 coupe sr20det
im using a speed sensor from my sohc 1990 it works. my tach doens't work though cause it's still the sohc
driftiteasy0113
Car: SR PIGNOOOZZZE
so would i just need the tach sensor from a dohc then and still use the sohc dash plug?
driftiteasy0113
Car: SR PIGNOOOZZZE
Justin35ll wrote:im using a speed sensor from my sohc 1990 it works. my tach doens't work though cause it's still the sohc
so are you still using the sohc dash plug? or did you splice the dohc?
DuckyD
Car: 1995 240SX
Steady_One_S13 wrote:Make sure that the KA 5-Spd sensor is from a 91-94 DOHC.
I am fairly certain that SOHC speed sensors also work. As long as it came from a manual.
And Driftiteasy- You don't need a "tach sensor". As long as you have the DOHC cluster it will work just fine. Justin was referring to his tach not working because he is still using a SOHC cluster.
driftiteasy0113
Car: SR PIGNOOOZZZE
ok thank you friends. i am doing this tonight so i will let you know how it goes
Wretched
Car: 93' Hatch
I never messed with speed sensor...always used the one from the sr. Check out frsport.com about what to do with the dash plug.
Steady_One_S13
Cool. if it works, use it.. Never tried one.
